21 - 28 of 28 Posts
@Huntingky Nah try a Ferrari, I think it was a 308 the carpet was glued to the floor. Had to use a razor blade to carefully separate it to make an area to run the wiring. But I do understand your comments about Saab, we used to call them Sorry A*$ AutomoBile.
Ha ha....never worked a Ferrai, Porsche Ruf Turbo was most exotic I ever touched, don't even remember it having carpet. It was the loudest car I ever worked on: all sound deadening removed, open exhaust engine right behind you. The 308 sounds though like some of the motor homes I worked though: carpet and paneling glued on, sometimes stapled. What ever they could do to get it put together quick and cheap. No thought to later removal. HATED running wires in them.
Spark plug changes on any Subaru with a boxer engine. (Take everything in the way out on both sides of the engine, use a length-adjustable 3/8 drive extension and a tight plug socket) Plugs are in-line with "frame" rails of the unibody and they are DEEP in the engine.
Replace the 2007 Hyundai Sonata 3rd brake light bulb. That means disassemble most of the rear.... like the rear seat, package tray, etc.
Same Sonata but the ash tray in the center stack. Accessing one of the 4-5 screws means you have to remove the floor console and the center stack. A ten minute job becomes a 2 hour one.
Agree with you about the Subaru boxer spark plugs. To change the ones on my Outback I remember moving things out of the way and feeding in a spark plug socket, then feeding in a short extension and engaging the socket, then feeding in another extension to engage the first extension and then getting the ratchet engaged. Once the spark plug was loosened you had to somehow disassemble all those parts and take them out one at a time until you could finally get the spark plug out by itself.
When we were kids my brother had a Pontiac 6000 I think it was and to change the spark plugs in that we just drilled three holes in the firewall and did it from inside the cabin.
Didn't have a Pontiac 6000 experience..... sounds like something I'd do too though.
I forgot about reconnecting the coil packs on the Subaru. You had to be very careful with their 0.00003 cent plastic connector plugs. One false move and
it would be jacked up physically and would no longer click into place & make a good electrical connection to the coil pack..... a few miles later you'd have the dreaded PO301 misfire code.
(you'd then chase your tail for hours trying to figure that out...... not making the "connection" to what just happened when you changed spark plugs)
More fun than any human should be allowed to have.
Discussion Starter #25
When the Volvo blew, a "friend" sold me a Subaru boxer winter beater. Guess I gotta sell it before I put plugs in it...
My worst job was replacing head gaskets on our 95 Windstar many years ago. Wasn't the winter but right in the middle of a heat wave in August. I had to fashion a tent with a tarp to keep the sun off of me. Everything little thing on that motor had to come off in a specific order or you weren't getting anything off. Man I still have cold sweats thinking about that job!
I did a water pump in a motor home last August. What a nightmare!!!
Had a 96 Mercury Tracer wagon many years ago. The heater core sprung a leak, so figured I would replace it. Got really nervous when the repair manual started off with: 1 - disconnect negative cable from battery; 2 - remove air bag from steering wheel. WTF? The heater core is on the other side of the dash; why am I removing the steering wheel? Ended up being a 2 day job, and had a small handful of leftover parts and screws. Don't know what they were for, but had no more issues and sold the car when it had over 330K miles on it.
Heater core went in my Jeep Grand Cherokee 1999, I think they put the heater core on a pedestal then assemble the Jeep around it. When it leaked, I bought the best radiator sealant money could buy and its held for 2 years so far.
A relative of mine had a girlfriend for a while with a Saab 900 Turbo. We didn't care for her too much, so she got nicknamed Turbob!+ch. I had to wash and vacuum the car as a punishment once and I remember thinking it was probably the most expensive PoS I had ever sat in. It looked like everything that was wrong with the 80s was crammed under one hood.
I had a 1991 SPG I put 250k miles on. It was likely the best car I ever had, ran like a sewing machine, it was a blast to drive and was well laid out for comfort on a long trip. What I total bitch to work on though. Accessory belts up against the firewall UGH!!!
Used to help people out with car stuff in college for beer money. Once someone ask a buddy and I if either or both of us would help changing the clutch in a Fiero. Looked at it briefly, no F'n way. In the parking lot of dorm? Absolutely not.
Buddy of mine asked if I would help change injectors on his Duramax. Looked into it and said no f'n way too.
He lucked out though and found a chevy factory mechanic who does side work and got them done for about 5 grand.
Administrator
Good move, Duramaxes are no joke. Things are built in layers. More tubes and bits than anyone would imagine a diesel needs. And Lord forbid you should try and reassemble with one tiny bit out of order. Did a head gasket on an '05 and the garage was full of parts before I got to where the actual head was. Amazing. '10 and up trucks have trimmed away some of the excessive bits stuck on the engines but are still pretty much a cluster.
21 - 28 of 28 Posts
