1 - 2 of 2 Posts
how does the pitman arm connect to the centerlink on manual steering? does the centerlink come with a fitting or does the pittman arm have it, i am switching overfrom power and the threaded part on my p/s unit stayed on the pittman arm , thanks guys
The manual and power steering V8 cars use the same pitman arm, sounds to me like you used a pickle fork or some means to separate the control valve from the pitman and in the process destroyed the ball stud socket in the control valve by pulling it out of its seat /forums/images/icons/frown.gif. You will have to just knock out remaing piece from pitman arm.
1 - 2 of 2 Posts
