I received my deluxe report from Marti along with a new door tag containing 2 rivets in the 2 holes of tag that appear popped. There were also 2 additional rivets in the package that also appear popped.Can these be used to fasten the door tag to the door or am I missing something?...Rivets typically contain a nail on 1 end with a rivet on the other. Anyone receive the same and what did you do to install the tag. I know that the original rivets had a larger hole than most rivets that you see today,Any replies would be appreciated, Thank's, Alan
The door rivets do not always get the plate tight to the door. I like to use a small amount of contact cement on the back and on door. To put the rivets on, made an "installer" out of a dowel trimmed down to fit opening in the rivet and keeping end of dowel flat. I put a dab of cement on hole in door and gently tapped in the rivet. Other things can be used but it doesn't take much to "total out" a rivet if hit too hard. :) You were sent the correct attachments to fit the plate.
Those rivets are meant to center punch. Just put them in the holes and tap the center of the rivet with a blunt nailset or similar object, they will expand and should hold well. Be careful not to tap too hard as you will poke right through ;)
blkstlln
Discussion Starter · #5 ·
Many Thank's, so the extra set of rivets are just that,? Alan
