I'm getting ready for my weekend project on my '66 of changing the original single res. master cyl. to a dual res. master cyl.. I'm using a '74 Mavrick, which I hear is a direct bolt-on and I'm also using a propurtioning valve from a disc equiped Granada because I never changed the oem propurtioning valve when I installed the disc brakes a few months ago. I'm trying to understand what lines go where on my propurtioning valve and also looking for advice on the master cyl. swap.
Thanks!
some info on front page of this website under faq/s. i did exactly this changeover. youll probably get lots of help on this. if not i can go out and look at my valve/lines,etc. for you. i just dont remember now. i used the 74 master cyc. also drum/disc-perfect fit.all granada stuff like you,works well i think.
