1 - 1 of 1 Posts
1st. I'd like to thank everyone for responding to me last week, thanks. Earlier, I had put the 1406 from my coupe on the 460 and didn't really notice any difference. In hind sight, this was because I still had a big vacuum leak. Since then, I hadn't tried it again, also I didn't had the throttle cable hooked up because I didn't have a ballstud for the linkage.
Friday when I went home from work, I dug in again and re installed the 1406. I didn't hook the choke open because there was a difference in the electrical connector, so I just stuck a screw driver to hold the choke open.
When I started it, it ran better. It still popped through the carb a few times but then I realized the engine was cold, the choke wide open. My Mustang reacted the same way with the same carb. before I hooked the choke up. After the truck warmed up, it ran good, real nice throttle response............untill it ran out of gas! *LOL*
I guess its time to get a new carb. The 1406 is 600 c.f.m., and emmission style carb. Or do I get the 1411 750 model for the 460? I realize the 750 is a better choice for the size engine but I also need to pass the sniffer test.
Tom
You can do anything you want to......ONCE!
aka "my 66 coupe"
1 - 1 of 1 Posts
