1 - 13 of 13 Posts
Searched but no luck so I need some pic’s of a Metal front valance that was made to look like a R model.
All I saw for sale where fiberglass or plastic ones. I suppose you could cut the center of your front valance and fold the bottom section and sides inward but you will need something to join the corners so a little welding would need to be done. I remember somebody on here having done one recently as a means of getting more air to the radiator. I even thought just removing the area where a license plate would go would improve airflow or would be a great place to mount a trans, oil, or even power steering cooler if it didn't reduce flow or transfer heat to the main radiator. When you wanted, you could even put a license plate over it to cover it up.
Yes it was posted here as I remember seeing it and thinking about doing it as I’m almost ready to get into that..I have the MTF upper section almost fitted and ready to make that mod..
748818
Patrick... is that yours?
I used a license plate for a template on the stock valance and cut it out, worked great!
Reactions: cougar70 and Nos681
What did you use for air inlet and diameter?
Looks nice.
I had looked at garbage disposal opening in past, when I was looking to do that.
The reason, it has a nice smooth radius.
Spammer Hammer
James...I like that as well.
1 - 13 of 13 Posts
