·Guest
MIKE
Need more help.
Is there a knock out hole in the firewall that accepts the rubber boot for the clutch pedal rod ?
I also installed an after market power brake set up from Master Brake Inc do you think I will have a clearance problem with the Rod Equalizer to the Equalizer Lever.
I live in Michigan and will be starting this conversion in about 2 weeks and have a big favor to ask you.
Would you consider giving me your E-mail address so I may contact you direct instead of going thru the Forum I promise I will not bother you more that 1000 times.
Dennis (E-Mail [email protected])
Need more help.
