1 - 2 of 2 Posts
20.00 AIR DUCT goes from core support to aircleaner snorkle 302 ,D3ZF 9A624 A b10231 2
20.00ea BUMBER BRACKETS front 73 , both have some rust circled b7310013
75.00pair BUMBER BRACKETS front 73 , nice shape ,pair b10236
15.00 BUMBER BRACKETS front 71-2 RH b10244 15.00 BUMBER BRACKETS front 71-2 LH b10245
20.00 BUMBER GUARDS : 73 rear ,some pitting b10254
30.00 CORE SUPPORT/HOODLATCH BRACKET : bolts to center of core support and to hoodlatch ,single upright b10380 3
45.00 CORE SUPPORT/HOODLATCH BRACKET : bolts to center of core support and to hoodlatch ,dual uprights ,4pc b10381
10.00 COWEL insert b7110202
10.00 COWEL insert b7110203
75.00 FAN SHROUD D3ZE-AB b100
10.00 FENDER-BUMPER rubber insert b7110204
15.00 FENDER EXTENSION : 73 RH painted b10268 2
15.00 FENDER EXTENSION : 73 LH painted b10269
15.00 FENDER EXTENSION : 72 LH chrome , no pitting has sanding scratches b10268
125.00 GLASS ,DOOR : fastback ,RH ,sun-X
125.00 GLASS ,DOOR : fastback ,LH ,sun-X
100.00 GLASS ,DOOR : fastback ,RH ,clear
100.00 GLASS ,DOOR : fastback ,LH ,clear
85.00 GLASS ,DOOR : Hard top ,RH ,sun-X
85.00 GLASS ,DOOR : Hard top ,LH ,sun-X
75.00 GLASS ,DOOR : Hard top ,RH ,clear
75.00 GLASS ,DOOR : Hard top ,LH ,clear
50.00 GLASS ,REAR WINDOW : Hard top ,clear
75.00 GLASS ,REAR WINDOW : Hard top ,SUN-X
100.00 GLASS ,REAR WINDOW : fast back ,sun-X
10.00 HEADLIGHT BUCKET : RH , b10397
15.00 HEADLIGHT BUCKET BRACKET : RH ,bolts to fender encases bucket b10393
15.00 HEADLIGHT BUCKET BRACKET : LH ,bolts to fender encases bucket b10394
10.00 HEADLIGHT BUCKET BRACKET : bottom plate b10395
5.00 HEADLIGHT BUCKET BRACKET : angle bracket bolts assy to core support b10395
10.00 HEADLIGHT RETAINING RING : 71-2 stainless ring hold headlight b10407 b6579
10.00 HEADLIGHT RETAINING RING : 73 stainless ring hold headlight b10408
10.00 HOOD LATCH : for single upright core support bracket b10386
25.00 HOOD BEZEL NASA : RH potmetal bezel for NASA hood b10411
25.00 HOOD BEZEL NASA : LH potmetal bezel for NASA hood b10412
15.00 HOOD BEZEL INSERT NASA : LH , honeycomb block off insert b10413 HOOD BEZEL NASA FASTENERS: studs and nuts for bezels b10414 HUB CAPS : link to all hubcaps
10.00 GRILLE BRACKET : use with single upright core support bracket b10384
15.00 LICENSE PLATE BRACKET front 73 new b10232
50.00 MIRROR SPORT : sport LH nice b10356
35.00 MIRROR SPORT : sport LH ,remote knob broken b10357
35.00 MIRROR SPORT GASKET : sport gasket b10357
30.00 MIRROR STANDARD : standard LH nice b10356 2
30.00pr MOTOR STAND mounts to frame and motor mount ,V-8
5.00set MOTOR STAND BOLTSV-8 b10375
10.00 PARKING LIGHTlense 71 LH ,in valance, SAE PI 71MG b10280
10.00 PARKING LIGHTlense 71 RH ,in valance, SAE PI 71MG b10281
15.00 PARKING LIGHThousing 71 RH ,in valance, b10282
15.00 PARKING LIGHThousing 71 LH ,in valance, b10283
15.00 PARKING LIGHT73 in grill ,D3ZB 18215 AA b10284
15.00 PARKING LIGHT73 bezel ,in grill ,D3ZB 18237 LH b10284a
15.00 PARKING LIGHT73 bezel ,in grill ,D3ZB 18237 RH b10285 2
20.00pair RADIATOR BRACKET upper 3 inch b10218
20.00pair RADIATOR BRACKET upper 3 1/2 inch b10219 2
25.00 REAR QUARTER-BUMPER FILLER : 73 LH ,has one stud broken b10271
20.00 REAR QUARTER-BUMPER FILLER : 73 RH ,has chip out of rubber b10272
5.00 SHOCK TOWER CAP bolts on top of shock tower and to shock b10213
10.00 SHOCK TOWER BRACE RH ,bolts on top of shock tower and to cowel b10229 3
10.00 SHOCK TOWER BRACE LH ,bolts on top of shock tower and to cowel b10230 3
20.00 SHOCK TOWER OUTER BRACKET LH bolts to outside of shock tower covers coil spring b10392
15.00 SIDE MARKER front b10274 4
15.00 SIDE MARKER rear b10275
10.00 SIDE MARKER trim front RH b10276 3
10.00 SIDE MARKER trim front LH b10277
10.00 SIDE MARKERtrim rear RH b10279
0.50ea SIDE MARKER nuts b10278
20.00 SPLASH SHIELD LH rear D1ZB 16569 A b10264 2
20.00 SPLASH SHIELD RH rear D1ZB 16568 A b10265 2
20.00 SPLASH SHIELD RH front D1ZB 16562 AC b10266 2
20.00 SPLASH SHIELD LH front D1ZB 16563 AC b10266
35.00 TAILLIGHT assy nice b10438
50.00 TAILLIGHT PANEL TRIM : honey comb , cracked b10452
20.00ea TRIM: grill ornament standard grill nice bt7310198
20.00 TRIM: grill center coral standard grill nice bt7310080 2
40.00 TRIM drip rail FB LH bt7110045
40.00 TRIM door jam weatherstrip FB LH bt7110046
50.00 TRIM door jam weatherstrip HT pair bt7110046
10.00 trim headlight ring 71 72 mach 1 RH b7110015
40.00 trim rear window set HT bt7110035
40.00 trim rear window set HT bt7110036
150.00 trim rear window set FB real nice show quality bt7110042
35.00 trim rear window lower pair FB bt7110065
35.00 trim taillight panel set peble finish bt7110040
35.00 trim taillight panel set peble finish bt7110041
10.00 trim tailpanel thin lower non flip cap bt7110068
35.00 trim tailpanel thin upper for flip cap bt7110069
20.00 TRIM: VALANCE front valance bt7310092
15.00 trim windshield rh bt7110043
15.00 trim windshield lh bt7110044
150.00 trim windshield set outer convertible bt7110063
40.00 trim weatherstrip a-pillar convertible pair bt7110063 WHEELS : link to all wheels
50.00 WIRE HARNESS: taillight harness ,no cuts bwh7110012
175.00 WIRE HARNESS: 71 dash harness ,with AC ,no cuts bwh7110016
175.00 WIRE HARNESS: 73 dash harness ,with AC ,no cuts bwh7310027
125.00 WIRE HARNESS: 73 HEADLIGHT HARNESS ,with AC ,no cuts bwh7310028
65.00 WIRE HARNESS: 73 taillight harness one socketr replaces bwh7310029
35.00 WIRE HARNESS: 73 neutral saftey switch fmx bwh7310039
30.00 WIRE HARNESS: 71 engine gauge feed 351c ,std insturment cluster bwh7110035
125.00 WIRE HARNESS: 71 headlight harness with AC , no cuts bwh7110017
50.00 WIRE HARNESS: 71 taillight harness , no cuts bwh7110018
here is a link to pictures
http://vintage-ford-parts.com/BP71.html
here is a link to the rest of my parts
http://vintage-ford-parts.com/index.html
[email protected]
1 - 2 of 2 Posts
