I am about to replace the modulator valve on my C4. The question is.....is there a starting point for the adjusting
screw then so many turns out?
You can adjust the shift points by turning the screw CW for shifts at a higher RPM or CCW for shifts at lower RPM's.
The adjustment is located inside the vacuum fitting. Usually close enough "out of the box".
Like the others said, try using it right out of the box. If you want to try to adjust the shift points, go 2 turns at a time and see how it runs. The performance will also depend on what you have done to the transmission and engine. On my old 289 w/ C4 and no shift kit, tightening up the modulator worked pretty well, and I was able to get crisper shifts out of it. With the new 331, and a rebuilt C4 with shift kit, tightening the modulator didn't seem to help, in fact, i thought it made it worse. The tranny didn't shift at higher rpm, but it seemed to make it more of a clunky type shift and it took longer. When I backed the modulator it shifted quicker and cleaner.
Dave
