41 - 53 of 53 Posts
Discussion Starter #41
From under the car using socket extensions you can usually reach it.
I was trying to do it in my garage, and I don't have any lifting equipment. I'll take it in to the workshop and get it on the lift - should make it easier to get to groin underneath. Now my only concern is if the bolts break. Don't know when the last time it was removed was. Could be 5 years, could be 53. :/ going off my experience with this car, I'm putting my money on the latter!
1966 289 Auto Coupe
Discussion Starter #43
What AC bracket are you using ? It sits nice and low.
It is the one that came with the Classic Auto Air Daily Driver kit I purchased (through CJ's, but came directly freon the manufacturer). I will have a closer look and see if there are any part details either on the bracket, in the instruction manual, or on the invoice.
1966 289 Auto Coupe
Happy endings are always free! Nice to see this getting sorted.
Export brace installed. New shocks coming on Tuesday (maybe I should have waited and done it all at once).
Next is replacing the exhaust donut - just have to find a way to get to those damn nuts, borrowed an impact drill, but can't get it under there, and can't seem to get any leverage under there to use a wrench :(
1966 289 Auto Coupe
Should I tighten the bolts on the Monte Carlo bar while it's still jacked up in the middle of the engine crossmember?
Or do I follow the same principle as with suspension - don't tighten until the car is back on the ground?
I started with the factory bolts, but when I checked clearance to the hood with some clay I found almost none so I changed to the carriage bolts.
Same for me when I checked my homemade bar for fit. I thought the issue was my repro hood. Carriage bolts are my only option and I'm fine with that. Btw, the bar I bought initially was just manufactured too long. My SD export brace was already bolted on the car and I had to cut a nice chunk out of that first monte carlo bar to fit.
My 66 is very solid. My export brace didn't want to fit either. Even after jacking it up. So I cut and welded the brace to fit.
Ive read through several of these threads the past week as I was getting ready to install the braces and bars in both my 65 and 67.
My 65 uses 5/16-24 bolts for the shock cap.
My 67 uses 3/8-16 bolts for the shock cap.
"Uses" means that is what is on the car and they loon oem to me.
I could have squeezed the 3/8 bolts on the 65 but I would have had to grind the head flatter and file the shoulders down a bit.
I used the oem bolts on the 65 and Im not happy with them. After adding the STB, I think I need a 3/4" long bolt vice the 1/2" long bolt, so this winter Im changing them out.
In have a TC export brace coming on Thursday. Hoping I do not have to much trouble getting it on.....I think it will go in fine. Can be adjusted :) I will look to the monte bar next.
I had to take about 3/8" out of mine. I tried everything to get it to fit, but had to cut and weld it to get it to fit.
With the tolerances these cars had and the life they led, I should be happy with only having to cut 3/8" out!
If you cut your MC bar, where do you cut it to minimise loss of torsional strength?
I cut mine one third of the way across.
After cutting the bar, I drilled three holes equidistant (120 degrees apart)through the bar on each side of the cut.
I then placed an an appropriate piece of tubing(tight fit) 4" long inside of the bar.
I plug welded the holes and then welded the cut. The inserted tubing helps to keep the bar straight.
If I wanted to do it the aircraft way, I could have cut the tube on a diagonal. No way was I going to all that trouble!
41 - 53 of 53 Posts
