1 - 2 of 2 Posts
I've been e-mailing with tech support at Hays with questions about my clutch & pressure plate application. They will inspect and rebuild the clutch disc for $35 & the pressure plate for $50. new the disc should measure .320" to .330". Checked mine earlier and it is approx. .260". What do you guys think?
I have almost always taken my clutches to a rebuilder, advised them of the specific application, use, etc and have always been very pleased, and you are right, it is usually a little cheaper too. Although I am sure Hays will do you a fine job, you should be able to find a local clutch builder who should be able to rebuild the whole thing in about 2 hours.
FYI: I use Clutchmasters in Colton California
Jeff
Jeff
Member: Flatheads ain't so bad association
Never trust an over 40 Chevy owner association (They have to cheat to win)
1 - 2 of 2 Posts
