Time to bring some more life into my car.
I currently have a 302 4v out of a 1974 Maverick. It has been worked on because they where only 2v, and I have an Edelbrock 4v carb on top of it.
I've debated putting in a 351w with fuel injection, but I thought if I could maybe get what I'd like out of the 302 then I could save some head ache. All of this brought upon cause I have to realign the distributer and thought why not add more power, lol.
I have a general idea, but I'm lacking knowing for sure of what I should do. My budget is pretty limited, so the the "just stroke it and add a supercharger" way is out of the question.
I would like to have at least 300hp, something about being under that number just irritates me when it's a muscle car.
The engine is pretty strong, though it does seem to need a while to be warmed up before use, other wise it bogs itself down when I stomp on it. I'm not sure what's doing that.
I have noticed that one of the cylinders tends not to fire when it's at an idle, but goes away with a little gas.
Is it worth going through all the effort to put in new parts, or should I just look into finding a 351w?
Any recommendations of what to do to it? Remember my budget is tight, if I had $1000s to spend I'd just buy something new and already built up.
You have several options but seing as you have no issue with going with different motor why not opt for a late model 5.0 roller motor. There are plenty at the wrecking yard and if you dont want to go EFI getting 300 horse from it should be no prob with a low budget. What is your budget?
I'm thinking the 5.0 roller might be a good way to go, as long as I can bolt it up to the toploader and use everything else while I'm at it. I'll probably just fix my distributer tomorrow or whenever so I can drive it around in the mean time (nothing worse than really wanting to go for a drive and not being able to) and then put in a 5.0 when I find a good deal.
Any idea what they usually run for? How about particulars to look for?
*budget is currently one of those "how far can I stretch $2.15" kinda things... lol
How many miles are on your current block? I would access the current state of your engine by running a compression check, and obvious things. Does it consume oil? burn coolant etc? If the engine checks out, i would then start throwing parts at it. A good, tuned carb and igntion is the base of everything. 600cfm for your 302. Matched with a decent intake, exhaust (headers, h/xpipe etc), ported factory heads with a valve job, and a mild cam is good for 300hp range.
Thanks for the info.
Miles I'm uncertain on, it runs strong and I haven't noticed it burning out much. Looks like a good place to start...
If your current engine is running well, why not convert it to EFI and do a cam swap? What type of exhaust and gearing is in the car now?
