1 - 11 of 11 Posts
Hey anyone know of motor mounts for a 68 302 Convertible,[has the 67 style brackets] I can buy from auto store, Just looking for a stock mounts for a daily driver, Don't want to spend 200 for the adjustable ones. I also have a set of 68 coupe brackets I could use, but not sure how that would work.
68projectcar
68projectcar
Yes, all 67 289, all 68-72 convertible 289/302/351, and 70 BOSS 302 used the C7ZE insulators.
The Mustang Barn sells them. They are the only source.
I just received my mounts from Dan last week. They look good. They have a jig and cut/weld to make the C7ZE mounts. I think they're $190 + shipping.
I have been putting a clutch, rear main seal and up-pipes in my Ford F-250 4X4 Diesel and have not found the time to install Dan's new mounts. The mustang is my parts go getter.
Discussion Starter #8
motor mounts
yes, I spoke with him on the phone, $200. for him to make a pair, got to be something out there that will work, that's a lot for motor mounts.
I have owned two 67 mustangs with the same problems the mounts will fit if you pry them into place than the driver side last 6 month before it rips because of the load.
On my present 67 I redrilled the frame mount to the proper angle, there are templets on this web site, now my 289 just drop in like it should
I agree, way to much money for mounts. On the other hand, they fit. They will also be the last mounts I buy for my 67, hence the reason I bought them.
Gary
What do you have against pinning the ones you have? Cost almost zero, will last forever.
It's pretty much that or spend $200 to do it the "right" way.
Assuming you don't want solid mounts.
Russ
1 - 11 of 11 Posts
