Well, finally got this done this weekend. I routed all the wires, then this weekend I mounted this monster. (I have the 21 circuit, a bit overkill I know) Anyway, here are some pics in case it might help anyone else. I had already bolted in the windsheild wiper motor to make sure there is clearance. I went sideways because of how the wires lay, they are flatter coming out the bottom. So, to get the most length, I mounted it sideways. I have to take out the clutch/brake assembly one more time, and at that point I will run the wires over that. Now comes the fun part, attaching these stupid things. Guess I should go buy some soldering stuff and start learning. Any recommendations for a good soldering kit or just get something inexpensive at wally world? Also, I have the firewall pad attached by fasteners which is what the kit comes with. Is this enough or should it be glued in some areas?
Thanks.
http://www.flickr.com/photos/[email protected]/2254509145/
http://www.flickr.com/photos/[email protected]/2255308110/in/photostream/
http://www.flickr.com/photos/[email protected]/2255308054/in/photostream/
Looks good. The clips that hold the firewall pad in place should be enough. I assume the circuit box is going directly against the firewall? or against the pad? Held in place by sheet metal screws?
Yes it is directly against the firewall, but I didn't use sheet metal screws. I got long bolts with lock washers and drilled holes. I wanted to be able to cinch it down nicely withouth worrying about pulling the screw through the metal.
