okay okay, I know, the MSD hook up is simple, i got It almost hooked up /forums/images/icons/smile.gif. Anyway, Im using a new duraspark distribuor, with the one wire connecter. I have the diagram below.... What is that thing circled in RED? I don't have one of those..... or do I just hook the red wire up to a switched 12 Volt source? Any advice appriciated, because currently the car will not start. Thanks......
http://home1.gte.net/res00w92/msddiagram.jpg
Thanks!, If I have any more problems I will let you know tommorow! Thanks again!
What they are showing there is the "horseshoe" connector that slips over the business end of the coils that are used with teh Duraspark ignition systems. It just slides over the end of the coil to make the connections instead of screw studs or Faston connectors.
