MSD Ready-to Run distributor for a Ford 351w, model number 8354. Less than 1000 miles on it.
737731
737732
737733
737734
737735
737736
Retails new for $400. Price is $275.
Features:
  • Now includes built-in Rev Limiter!
  • Powerful built-in module produces a 7.5 amp single spark through high rpm
  • Easy-to-adjust mechanical advance with supplied springs and stop bushings
  • Vacuum advance canister for improved economy (can be locked out)
  • CNC machined billet aluminum housing and billet aluminum base
  • Housing is 5/8” smaller in diameter than stock Ford distributors
  • Maintenance-free magnetic pickup and precision reluctor create stable trigger signals throughout the rpm range
  • Polished steel shaft is QPQ coated and guided by a sealed ball bearing
  • Advance plate and weights are fine blanked from chrome moly steel and QPQ coated for friction reduction
  • Mechanical advance assembly can be locked out for crank trigger systems
  • Advance weight pins are staked and tig welded to the plate
  • Nylon pads ensure smooth operation of the advance weights
  • Supplied with small diameter cap with HEI style terminals and race rotor (will accept 8441 Cap-A-Dapt)
  • Does not require an MSD Ignition Control
  • CARB E.O. Approved
  • Simple and clean installation with only three wires to connect
MSD Ready-to Run distributor for a Ford 351w, model number 8354. Less than 1000 miles on it. View attachment 737731 View attachment 737732 View attachment 737733 View attachment 737734 View attachment 737735 View attachment 737736
Features:
Hi, I’m very interested in this distributor but am unfamiliar with the sales technics on this site. I also have a msd 8584 to trade if your interested. It has been installed but never run. I’m lookin for vac advance for street. Please contact me. Jeff
738018
Jeff, pm sent
Discussion Starter · #4 ·
Still for sale
