Translate Google
Hello
Difficulty out of 5: *
On Mustang 1967 Cost 25 €
For those who have a model 1964 to 1966 and 1968 to 2005 see post same day 19h20
I had two flashing repeater slots under my hood, but no holes for them on the hood.
So to plug it's holes a light for engine compartment
Accessory
1 plate coppery aluminum (grid) 25 x 50 About 6 € if the color you do not like a blow of bomb.
It will take twice 32 x 11 cm (minimum attention 31,5 x 10,5 it forces you to center well)
1 flat aluminum stick 2 cm x 2 mm minimum length 1.28 m About 4 €
It will take 4 times 32cm for side stack and face, on one side it should be enough if we place well these rivets
4 led 19 cm x 35 mm total 1000 lumens for 4: 8,80 €
Manufacturer description 500 lumens 10w I think these numbers are for the 2 (so 4: 1000 lumens 20 watts)
Rendering of 4 lit at least 1000 lumens
8 Rivets at 4mm Hole Eye View
6 rivets (inserts) threaded (rivet with screw thread), for 6 mm screws
If you do not have the pliers you drill 7 mm and on the other side you glue a flange nut (glue two components)
Another possibility (I have not tried yet) threaded inserts 6 mm
6 screws of 6 mm for the moment I put temporary (the final (see photo 9) head round the 20: 6,30 €)
You can take standard hex head screws or others in stock
1 plastic switch it will handle the negative in stock about 0.60 €
1 fuse 5A
Attention if you drill to put a switch protect under (the sheet of the cover) by a piece of metal from 3 to 5 mm thickness taped
I can not put photos
https://www.mustangv8.com/fr/electricite/eclairage-puissant-compartiment-moteur-led-'discret'/
Bonjour
Difficulté sur 5: *
Sur Mustang 1967 Coût 25€
Pour ceux qui ont un model 1964 à 1966 et 1968 à 2005 voir post même jour 19h20
J'avais sous mon capot deux emplacements pour répétiteurs de clignotant, mais pas de trous pour ceux-ci sur le capot.
Donc pour boucher c'est trous une lumière pour compartiment moteur
Accessoire
1 plaque alu cuivré (grille) 25 x 50 Environ 6€ si la couleur vous plait pas un coup de bombe....
Il faudra 2 fois 32 x 11 cm (attention minimum 31,5 x 10,5 ça vous oblige à bien centrer)
1 baguette plate alu 2 cm x 2 mm longueur minimum 1,28 m Environ 4€
Il faudra 4 fois 32cm pour coté pile et face, sur un seul coté ça devrait suffire si on place bien ces rivets
4 led 19 cm x 35 mm total 1000 lumens pour Les 4: 8,80€
Description fabricant 500 lumens 10 w je pense que ces les chiffres sont pour les 2 (donc 4: 1000 lumens 20 watts)
Rendu des 4 allumé au moins 1000 lumens
8 Rivets à vue d'oeil trou de 4 mm
6 Rivets (inserts) filetés (rivet avec pas de Vis) , pour vis de 6 mm
Si vous avez pas la pince vous percez 7 mm et de l'autre coté vous collez un écrou à embase (colle deux composants)
Autre possibilité (j'ai pas encore essayer) inserts filetés taraudant 6 mm
6 Vis de 6 mm pour le moment j'ai mis des provisoires (les définitives (voir photo 9) tête rondes les 20: 6,30€)
Vous pouvez prendre des vis standard tête hexagonales ou autres en stock
1 interrupteur plastique il gérera le négatif en stock environ 0,60€
1 fusible 5A
Attention si vous percez pour mettre un interrupteur protéger dessous (la tole du capot) par un bout de métal de 3 à 5 mm d'épaisseur scotché
Hello
Accessory
1 fuse 5A
Bonjour
Difficulté sur 5: *
Accessoire
1 fusible 5A
