Are the exhaust manifolds(390) from a 68 Cougar the same as a 67 Mustang(390)? Also are the motor mounts the same? I have been getting different info.
Manifolds - yes
Mounts - yes
The connfusion lies when you compare 67 and 68 small block mounts. The 67 uses big block frame perches with a unique small block rubber isolator. The 68 small blocks and big blocks are different perches and mounts
Bottom line, they will work fine for an FE. I do need to add that I am talking about usable, visually comparable mounts, for a concours type car, I am the wrong guy for part #'s
part # for right side should be same,C6OE. left side can be either C6OE (67) or C7OE (late 67/68) but they all fit the same. 67 used a flap in the right spacer, 68 did not
