That sounds cool. Have a pic?The track threatened to ban me from racing for leaking gas out the back when I launched. I didn't even know it was leaking. I got the 71 mach 1 new and improved flip up gas cap that is not the cap, just a cover. It has a screw on gas cap under that. It fits my 65 like it was made for it.
Stick this in the rubber hose....During the summer I watched quite a few 65-70 Mustangs at drag strips and noticed that quite a few that were really quick cars had fuel splash issues of fuel coming out the rear fuel filler cap area as they launched off the line.
What are some really good ways to stop that from happening aside from going to a custom fuel cell. My car will probably see high tens to low elevens so that is a concern.
I appreciate your input guys and thanks!
Hey, that's really spiffy. My '70 Mach 1 definitely has the fuel splashing issue. Looks like the check valve is a good solution.Stick this in the rubber hose....
Fuel Filler Neck Inlet Check Valve - 1-1/2" Hose
Tanks, Inc. manufactures fuel system components and polyethylene, steel and stainless steel gas tanks for street rods and special interest vehicles.www.tanksinc.com
Dang, same here, its 2.25" for 67-70 also. Maybe some modification is possible- maybe print a ring for a larger OD...if there is printer plastic impervious to gasoline. My local library will do 3D printing for next to nothing according to my son.I see that Tanks, Inc also have a similar 2" valve but nothing larger. The 65/66 filler tube hose is 2.25 OD, so one might have to improvise for either diameter to work properly.
PVC is "gasoline proof". Grab a stub piece of Schedule 80 2" PVC.... it's 1.913" ID and 2.375" OD. Cut a "ring" to go around the valve... a little bit of sanding and maybe so mild heat will allow it to fit over the 2" check valve. Stuff it at the bottom of the hose just before it hooks to the tank. Finit.Dang, same here, its 2.25" for 67-70 also. Maybe some modification is possible- maybe print a ring for a larger OD...if there is printer plastic impervious to gasoline. My local library will do 3D printing for next to nothing according to my son.
That is awesome! I am not sure what the inner diameter of a 67-68 filler neck hose is but I am going to measure mine tomorrow. I am going to get one if it fits! Thanks for posting that!Stick this in the rubber hose....
Another good idea! I will try that also.PVC is "gasoline proof". Grab a stub piece of Schedule 80 2" PVC.... it's 1.913" ID and 2.375" OD. Cut a "ring" to go around the valve... a little bit of sanding and maybe so mild heat will allow it to fit over the 2" check valve. Stuff it at the bottom of the hose just before it hooks to the tank. Finit.
Bart, unless this quick search revealed another internet untruth..PVC is "gasoline proof".
This related to PVC HOSE which I would never use in a petroleum application. PVC pipe material is impervious to gasoline because there is not enough BTEX in gasoline to swell PVC and cause permeation, especially in a non-continuous contact application.Bart, unless this quick search revealed another internet untruth..
