Best solution I've seen! What kind of nipple did you use and I can't make out the type of filter you used. Also, can you tell me where exactly on the quarter trim is vents out of? Thx!
Best solution I've seen! What kind of nipple did you use and I can't make out the type of filter you used. Also, can you tell me where exactly on the quarter trim is vents out of? Thx!My gas cap has double gaskets and the vent is closed. The fuel tank vents out the quarter trim. I have a glass fuel filter mounted near were the vent line ties into the filler neck. The fuel filter acts like a shock absorber when pulling G's and stops most if not all fuel from escaping. A mandatory fix that had to be done so I could continue competing. I fill my tank to the top before every event.
Just a 1/4"npt nipple threaded into the side of the filler neck. Not much to thread into and it has to be removed to remove the filler neck, I use a little RVT on the threads. The filter is a generic 1/4" tube glass filter from Amazon. 65 hardtops have a hole that is full of dum dum "putty" from the factory behind the quarter panel extension. I just removed the putty and ran the hose down the quarter panel extension and cut it off even at the bottom. You should have a rollover valve to be safe, It's on my to do list.Best solution I've seen! What kind of nipple did you use and I can't make out the type of filter you used. Also, can you tell me where exactly on the quarter trim is vents out of? Thx!
