I am looking at buying this setup. There is an option for 2-inch drop spindles. Is this too much of a drop? I am planning on 17x8 wheels on the front and was not sure if this will work out. Anyone done this with the 2-inch drop?
I have the Heidt's front end with the 2" drop spindles. Heidt's 2" drop spindle sets the car at the factory height. If you want to lower from there, Heidt's recommends cutting the coil spring. I believe that Rod & Custom uses Heidt's components on their crossmember. Someone correct me if I'm wrong.
Rod and Custom uses Heidt's drop spindles. The car will sit too high if you do not use them. At least that's what I was told when I ordered my kit.
Lstar
