1 - 2 of 2 Posts
My book says that the #1 cam bearing should be .005-.020 from the edge of the block, mine is about .025 from the edge(a little further back). How big of a problem does this pose? If need be, how do I move the bearing out?
TIA
Try to look for the hole in the center groove in the bearing. That is how the oil gets into the bearing. Try to tell if it is over top of the groove that is under the bearing in the block.If it is you will have no problem.
1 - 2 of 2 Posts
