They make a bracket that bolts to the bell housing bolt and places the clutch pivot ball where needed.
I had to grind part of the first one to allow the header on that side to clear. No major surgery was required...I just ground some off and sprayed it with some black paint. I just didn't like how it didn't allow the z-bar to be perpendicular to frame bracket which could have lead to some issues later on.My 65fb came to me with the one Lee posted on top, but I noticed the po had to grind a piece of the bracket for exhaust bolt clearance. I have bought the parts from the second link to replace it but have not done the conversion yet. For me it's going to be a much beter solution. kip
I have read about how those bolt on z bar brackets do not mount the zbar perpendicular with the frame side and that is why I am looking to drill and tap a hole.I had to grind part of the first one to allow the header on that side to clear. No major surgery was required...I just ground some off and sprayed it with some black paint. I just didn't like how it didn't allow the z-bar to be perpendicular to frame bracket which could have lead to some issues later on.
That's why I prefer the Wild Horses 4X4 bracket. It can be shifted both forward or backward to get the z-bar perpendicular. I don't know about the block you're using, but I put mine on a 98 Explorer 302 block because there is not enough metal in the correct spot to drill and tap a hole for the clutch pivot.I have read about how those bolt on z bar brackets do not mount the zbar perpendicular with the frame side and that is why I am looking to drill and tap a hole.
I've done it in the past with no issues on a NOS 1989 block I got off ebay. I copied the location from an early block, drilled and tapped the boss, then made the area flat. It really wasn't a big deal to do.I have a 1989 351W that is not drilled for a clutch pivot ball. I was wondering if a hole could be drilled and tapped without destroying the block. Has anyone on this site ever done this before? It looks like there is enough space to drill and tap a hole but the area would need to be grinded level before I could drill and tap.
Would it hurt the block if I did this? Has anybody did this before on this site?
Yeah that Wild Horses EFI clutch pivot bracket looks like a really nice and simple setup. I am going to buy one just in case I need it. Thanks for posting that info!That's why I prefer the Wild Horses 4X4 bracket. It can be shifted both forward or backward to get the z-bar perpendicular. I don't know about the block you're using, but I put mine on a 98 Explorer 302 block because there is not enough metal in the correct spot to drill and tap a hole for the clutch pivot.
That is good to know! I also have a 1969 351W that came out of a manual shift Mustang and it still has the clutch pivot ball located on the block. I can use that engine and measure where I need to make my hole to drill and tap. It looks like the blank area on the 1989 351W block I have has enough room to locate the hole. I will measure it tomorrow.I've done it in the past with no issues on a NOS 1989 block I got off ebay. I copied the location from an early block, drilled and tapped the boss, then made the area flat. It really wasn't a big deal to do.
Hey, you got this and it's a slam dunk! Since the 89' clutch boss is slightly different in outer appearance, I'd also consider taking measurements from other know fixed points (such as the bellhousing attaching flange and perhaps the oil pan flange) before committing to the drilling. I suggest this because I did the same and the hole ended up being offset somewhat on the casting (but still had plenty of meat.) Drill at a slower speed and use oil as a lube. You only need to drill deep enough to match the thread length of the pivot (with a washer.)That is good to know! I also have a 1969 351W that came out of a manual shift Mustang and it still has the clutch pivot ball located on the block. I can use that engine and measure where I need to make my hole to drill and tap. It looks like the blank area on the 1989 351W block I have has enough room to locate the hole. I will measure it tomorrow.
