Ok, I have the turn signal hood, the passenger side works all the time.
the drivers side /only/ works when it rains.
bulb is seated well.
Changed it out too. wiring /seems/ ok.
Any ideas?
1968 Coupe, 6cyl Std, Bench Seat. Driven through 10 years of College.
check the ground on the drivers side.
http://www.bluefinger.net/my066.jpg
Jason
Formerly Bluestangcom
"Got gas?"
Vintage Burgundy'66 Conv. 289 & C4. GT-ized
Strawberry/Silver '91GT
Guards Red 2000 Porsche Boxster
http://www.bluestang.com
Is the ground clean? And are you sure the wiring is solid? I'd check the ground first. I'm thinking that on that hood the ground is simply the mounting. To clean it youwould unscrew it, use a little piece of sandpaper on the socket and (carefully) on the hood where it mounts.
...modified '65 convertible...
Discussion Starter · #4 ·
My money's on the ground, too. I had to clean my right one up to get it to work. You should be able to tell by wiggling the plug while it is connected to the assembly and the light is on.
JT
'68 Coupe w/ 351w<P ID="edit"><FONT SIZE=-1>Edited by JTs68 on 03/30/01 01:41 AM (server time).</FONT></P>
