No such luck. The second time (when I used the weatherstrip cement), I actually removed the entire pedal assembly from the car, put on the pad perfectly, and installed a new stainless steel trim piece.my guess is that your not getting the pad fully on in the 4 corners, i say that cause i know how much a PITA it can be to full get it on. also you could try the stainless pedal trim. it has tabs you bend around the back of the pedal....looks nice too.
