hiya;s...
well here is a question...
if a valve body is bad on a tranny..what are the options?
i mean..can you replace it?
Discussion Starter · #2 ·
ok...so maybe it isastupid question...
but i'm astupid person...
soo...please...does anyone have a lil pity and a good answer?
Becareful tightening the bolts on the new valve body and filter retaining bolts as the valve body is sensitive to overtorquing.
Tom Kubler, Long-time Mustang Enthusiast & San Antonio Mustang Club Founder
No such thing as a stupid question!
The valve body can be changed but you should consult with someone more knowledgeable than me to find out which ones can be used in your particular transmission.
Usually, unless the transmission has sat with water in it or run without a filter, the valve body isn't the problem.... What's the symptoms?
Required tools for operating a Vintage Mustang:
1. Duct Tape
2. J.B. Weld
3. B.F.H. (Big Fat Hammer)
4. VINTAGE MUSTANG FORUMS II
View Album Here: http://albums.photopoint.com/j/AlbumIndex?u=1616948&a=12352157
Discussion Starter · #6 ·
Is that what you think the old problem is newbuds?
You can replace the valve body but in your case I think it needs to be from the same year (66 or it this a diff tranny). There were a few changes with the valve bodies and ones from some years won't be proper for other years. Valve bodies don't really go bad, just the components inside wear out. A shift kit will give you the springs and little balls and gaskets to rebuild a valve body. Consult the fourm before going ahead with this.
Discussion Starter · #7 ·
I never think any question is stupid!!! Always post away!! Yes, the valve body is easily replaced!!
65 coupe 302
(rebuilding a 351W)
