1 - 12 of 12 Posts
P
Do you have an export brace? You should aDD that at the same time. Your car will be better afterwards, promise.
And might as well do the Arning drop while you are at it (if you haven't already done so).
I had one bar from CJ that was so bad I think the only way it would have fit is if my car had been in a serious front end accident and never repaired. Both apron brackets were at different angles. I sent it back and bought one from Tony Branda. I don't have it in yet but at least the brackets are at the same angles and it does slip in with no issues.
1 - 12 of 12 Posts
