1 - 10 of 10 Posts
I had a friend tell me that my rear end is low/sagging.
I noticed the car was low in the rear?
I was told that is because the springs have sagged.
I want to get this fixed in the near future.
I called a place yesterday and they have a couple of used rear's out of some 289 stangs. Mine is the 71/2 on the I6.
I want to swap out this rear for one of the heavier duty ones. As I am working on getting parts for a front rebuild.
But maybe I should go to the rear first.
I was also told it is cheaper and easier to do the rear.
My question is, if I get one of the used rear ends, what size should I look for 8" or 9", I assume I will have to take this in and have a machine shop restore it. It is used.
What else would I need to replce with this, I have the I6 and a 3 speed auto trans? I know I'll need wheels and tires.
Anything else?
Comments would be appreciated.
Jimbo65
65 I6 200 Coupe (Daily Driver)
Discussion Starter · #2 ·
If your keeping your I6, I'd suggest looking for an 8 inch!! The 8-inch can hold up to 400 horsepower if built correctly!! So I don't see you needing more than that!! Hope this helps!!
65 coupe 302
(rebuilding a 351W)
Well,
Maybe not. I would like to do this with the intention of replacing the I6 down the road. I am doing the front this way. Just in case I decide to go that route.
Jimbo65
Discussion Starter · #4 ·
if ur rear is sagging why dont u just get new leaf springs¿ is a rear end upgrade in ur plans also¿ if ur just trying to get rid of the sag then get some leaf springs. that should take car of the problem.
Discussion Starter · #5 ·
Like I said, the 8-inch will hold up to most V-8's even!! Unless your going full out racing!! People always underestimate the 8-inch.
65 coupe 302
(rebuilding a 351W)
Discussion Starter · #6 ·
Jim,
My SWMBO said "This is a problem that I have, what can I do"?
I said, I'll get a younger SWMBO, without a sagging rear...!!!!!
Just a thought.....
Larry........... (hope she doesn't read this)
Hey ,
How do you get "?" upside down?
And "why" do you ?
If in doubt give it a clout
If at first you don't succeed , find a bigger hammer
http://albums.photopoint.com/j/view?u=1584152&a=12055089&p=43600042.jpg
Larry.
You sure do live on the edge!!!!!!!!!!!!
We need a photo of you ,SWMBO,and your car(s)
before you go on hols.
Deal?
http://albums.photopoint.com/j/view?u=1584152&a=12055089&p=43600042.jpg<P ID="edit"><FONT SIZE=-1>Edited by AussieMustang on 03/29/01 05:43 AM (server time).</FONT></P>
Discussion Starter · #9 ·
John.... living on the edge is a daily occurrence here....!!!!!
I have been married 4 times ...so far...!!! The question is, will I make it to 5.? We tied the knot in Las Vegas august '99..(lots of fun...LOL...) SHMBO and all of my family advise me it is about time I retired..! Seriously though we are very happy, I just have a very demented sense of humour..must have been my catholic upbringing..!! A photo ?.. I will try.. I have taken notice of the posts so far but have not tried to follow through.
SWMBO is the computer genius here- I'am just the house boy..!! I was going to put up a picture of my '70 falcon ute to show our american VMF'ers what they look like...good idea you think ?
Thank you for the invitation..........Larry
The cheapest change would be to just put in new springs. It's about a half-day job. If you are undecided about the V8 swap, just do the springs. You can build a lot of power out of the 200 I6. And the 6 cyl. car is better balanced than the V8 car because the weight is more evenly distributed. So, if I were you, I'd do the springs and then build up the 6 a little bit. Induction, ignition, exhaust. Drop it an inch or two, add front and rear sway bars and it'll surprise you.
...modified '65 convertible...
1 - 10 of 10 Posts
