Are you talking a reverse lockout for a 4 speed? If so what happens is the cable gets streched, it appears to be working-pulling bottom pawl up, but it doesn't do it far enough to engage slot in shifter body to allow reverse engagement. Your choices if so are to re-cable shifter handle, or shim up handle (add some washers in between handle bottom and U bracket it bolts to). Sometimes alot of old grease and crud build up and lead to this problem.
