Just upgraded the rear end on my '67 from 2.79 to 3.55. The old speedo gear (driven gear) was 18 tooth. According to my calculations, I now need a 22 tooth--which they don't make (the biggest has 21 teeth)!
What can I do?
Corcoran & Davis' Resto Guide says the drive gear is "part of the transmission output shaft," which makes it sound like it's not replaceable.
What, oh what can I do?
Speedometer shops use speedometer "gearboxes" that will correct your speedometer error.
You didn't specify what car or transmission you were working on, but automatics do not have a replaceable drive gear.
Had the same situation. As the previous post said you can chose a 21 or 23. I chose a 23 (from Steeda) since I actually needed like a 22.3 but the I read somewhere that the 23's wear out because the teeth or so small. Being within one tooth is close enough for most of us.
Had the same situation. As the previous post said you can chose a 21 or 23. I chose a 23 (from Steeda) since I actually needed like a 22.3 but then I read somewhere that the 23's wear out because the teeth or so small. Being within one tooth is close enough for most of us.
With my tires 225-60 x14's I need something between a 21 and 22, so I am going to go with a 21. You will be off less than 5% with a 21 if a 22 would be dead nuts on. 3-4mph at highway speed is not bad.
In my mind it is better to error by having the speedo read to fast than too slow. I'm less likely to speed.
Thanks for the suggestions!
According to my calculations, I need a 21.8 tooth gear (for a ’67 C4), so a 21 tooth gear is closer than a 23. Plus, I agree with Chris that it’s better to overestimate speed (especially in Wisconsin, where speeding tickets are the main source of municipal revenue). I can live with a 4% error (21/21.9 = 96% -- is this the correct calculation?). Plus, it’ll make my MPG look better!
Thanks again,
Steve
