1 - 2 of 2 Posts
need height of center of fender lips to floor of '67/'68 coupe 6-cyl.. put in Canadian Mustang "big Kit" and front seems high. VMFers have posted that height goes down in 6 months or so. have P205-70R14s at 32 PSI and have following values:
front right 28 in ., front left 27 1/2in., right rear 27 in., and left rear 26 1/2 in.. just provide your values and tire size and i will take it from there. thanks.
One of my manuals at home gives the dimension from the ground to the bumper bracket mounting holes on the frame. That's what I used to check my front after a complete rebuild with lowering springs and shelby drop.
It also gives the dimensions from the rear shackle mount to the ground.
My alignment shop told me my rear end was 3" too low even though the car visibly sits with the front lower. So I checked it and found they were wrong.
Anyway, if you PM me it will remind me and I'll get you the numbers later today.
I'll probably be going home early today! ::
Sorry, I can't give you my dimension because I have my diff disassembled for rebuild right now so the car is on jack stands.
1 - 2 of 2 Posts
