This was posted sometime back and forgot when. Anyway, have an early Ford Motorsport HO 5.0. It was rebuilt by Ford Authorized Rebuilders in about 1990. Bought it in late 90's still on pallet. It now has 14,000 miles on it. It was done with ported E7 heads, balanced, forged pistons, B303 cam, Hi volume pump. Want to put it in a 68 CV with a Lentech AOD that has a stall of 1800-2200. 3:25 9" rear. Previously, had it in a 65 GT and it ran great with a C-4 with trans-go shift kit and a 3.00 equa-lock. AC was not a prob. Problem is: am told to lose the cam, with the AOD, and I did get an Explorer cam which am told is a slug. Would rather not change it at all. Running a 600 cfm Edelbrock on a Shelby lettered Cobra style intake with Hipo exh. manifolds. Do not want to use headers-keep orig.look for insurance. Car has PS and AC. The cam, according to an article about the engine in MMonthly, in '90, said: 224 duration at .50 valvelift with 1.6 rockers, a total valve lift of .480" intake and exhaust lobe centers are 107/117 degrees. This is beyond me but post it for those who understand it.
Initially, had planned this deal with a '90 EFI setup but plan on staying with carb. I have the W-F shift rod, Lokar TV Cable, crossmember. One last question: Off hand, how much wider is AOD than the C-4. Hoping to use the Hipo H pipe?? Appreciate feedback, thank you.
