Hey Guys....
I have a 1970 Mustang I'll be running a 302 engine. Now the engine is out of a 1989 mustang 5.0 roller, but I will be using a carb system with a shaker setup.
What kind of carb size should I run?
Also, does anyone know the pulley size/number for the pulley on a power steering pump for a 1970 302?
The carb for that should be 600-650. Pulley choice will probably be limited to the offset you need. Will you be running AC? If you have a choice, go with the largest diameter that fits. You're running a high rpm engine, and you don't want a high rpm pump situation.
Biggest pulley I ever saw on one of these was the 67 289HP PS pulley:
I won a special award
Ditto. And don't use a double pumper. Get a vacuum secondary carb. Are you wanting stock steel pulleys? Or aftermarket pulleys? March Performance makes some nice aluminum billet pulleys. They're just not cheap. I have a set on my engine.
I won't have A/C, I also got to find a conversion 50 oz harmonic balancer for this setup.
I was thinking of a Holley Carb - 415 4V 650CFM electric choke....
