·Guest
I want to give my 289 2v a bit more HP but want to keep it street driveable.
The bottom end is sound, a compression check shows 130+ on all cylinders and had new rod and main bearings about a 1,000 miles ago.
I have a set of 1974 302 heads and a 68 4 barrel intake laying around. I want to put a new cam & lifter set in and get a Edelbrock Performer carb.
I will probably just get the Summit cam/lifter set but don’t know which one and should I get a 500 or 600 cfm carb.
After looking at the head interchange chart it looks like that 74 302 head on my 289 will make about 9.4:1 compression, Did I read that right.
Thanks for any help on this.
