·a couple days ago I took a drive from porlant to olympia (about 100 miles) on the way home it seemed that the engine was starting to miss occasionally at higher speeds ... the spedometer also seemed to be bouncing a little. the following day the miss progressed down into lower and lower speeds and now the car is pretty much undrivable it Idles faily well still though. I was wondering what things to look into ... I have not replaced anything yet. it did seem like there was a bit of noise coming from the rotor and one of the plug wires where it connects to the cap (the metal part) was all coroded the rotor looks a little worn but not too bad. I'm pretty new at this so .... well ... what should I do/look for??
BTW its a 289 w/ an automatic transmision and a POS 2 barrel carb ... and I have an exhaust leak at the manifold which I plan to fix asap.
