Hey everyone, its been a while. i havent logged onto VMF in months, as ive been conteplating the nature of being and the meaning (if any) to life itself by means of extensive philosophical research. Anyways, all good now :)
I have to remove both windows in my 1968 Mustang Fastback, and was wondering if someone had a step by step on how to do this? The glass on mine is scratched like hell, so i bought the glass of CJ pony parts. Here is link to what i bought...
got both driver and passenger side.
So i know i have to remove Vent window, and also remove the rubber stop at bottom of door to remove both inner and outer window seal on door. But what else would be required? Can i just remove window from regulator at that point and pull it out?
thanks!
You may not have to remove the vent window. There should be a little cover plate on the door at the rear end of your glass. You should be able to remove the attach bolts on the window bottom, lower the window then pivot it and slide it up and out.
