I’m just not sure which of these wires to hook up where.
I have one of these with the 3g kit I bought but my vehicle harness wiring doesn’t seem to lining up with the instructions. It came with the harness above and a regulator.I would get one of these.
EXTENSION HARNESS, FORD 3G ALTERNATOR - #F-14000-73AC - National Parts Depot
Buy part #F-14000-73AC EXTENSION HARNESS, FORD 3G ALTERNATOR for your classic vehicle from National Parts Depot. Free shipping on orders over $300, fast delivery & everyday low pricing! Order now!www.npdlink.com
I have an ammeterDo you have an ammeter or an alternator warning lamp?
Okay.... I missed the "3G" stuff.... Does this "kit" have a "dummy" regulator?I have an ammeter
It does have the dummy regulatorOkay.... I missed the "3G" stuff.... Does this "kit" have a "dummy" regulator?
Okay.... and your 3G alternator has a 3-pin plug that goes in the side with a pigtail with a ring terminal that goes to the BAT output post on the alternator?It does have the dummy regulator
Could you provide a picture of the above connections?Okay.... and your 3G alternator has a 3-pin plug that goes in the side with a pigtail with a ring terminal that goes to the BAT output post on the alternator?
Should be something like this.... As described elsewhere, I would NOT replace the original alternator output wire (yellow or black/yellow) but add a second 6ga wire with both terminating at a 100A fuse at the solenoid common (like this one... Amazon.com). I'd mount it adjacent to the solenoid and supply it from the solenoid common with a short 4ga wire.
