Hey everyone
I just installed a 9" rear from a 67 in place of the old 8" in my 69 coupe. Everything fit up fine, except the U-Joint. It seems like the old U-Joint is too small for the new yoke on the rear end. If anyone else has run into this problem when doing a swap, please help me out. all information is appreciated.
thanks
What is that yoke trunnion diameter, 1.062"??
You'll likely just need an adapter u-joint...
In the past, I recall using the yoke off my 8" on a 9" I put in my old street racer, but that required a new crush sleeve (I was changing gears anyway)....
'Course it's been over 20 years and my brain's a bit fuzzy on the details...*G*
Pat
Speaking of yokes, I was playing around with some yesterday-actually cleaning them up, I discovered that the 8" yoke would not fit the 9" pinions I had-smaller diameter splines than the 9" yokes.Back to the driveshaft issue, the 9" rear will most likely require a shorter one I believe.There are a few different length yokes available, I have started cleaning up some for my page, haven't measured any for cap or u joint size yet.Somone here a while back I believe was talking about this, believe they took two ujoints and made one-or at lest used the caps from one on another.Might try the search feature for this topic.Sorry can't help much more than that.
1967 S code GT Deluxe Coupe 65B
1966 Convertible 76B 289 4 speed
Descendent of Francois Seguin dit Laderoute,
Soldier Regiment d' Carignan, New France 1665-1668
Yup...OF brain fart..
The 9" yoke has a spline diameter of about 1.210" vs. the 1.095" or so for the 8" yoke...
I likely have what the poster needs...the 9" short yoke with the 1.062" diameter u-joint bore...all my other 9" yokes are 1.125" prox...
Too bad I installed a pinion brake disc on it...*G*
That's the yoke style I use in the race car with standard u-joints...no problems yet...
BTW, the pinion yoke retainer nut is the same on both 8" and 9"...go figure *G*
Pat
I also have a 69 grande that I put a nine in
I have a buddy at currie and he built it up so I would not have to shorten my driveshaft or change u joints if you need more info e-mail me at [email protected]
