I'm doing some work on the 64.5-66 registry and I'm looking for info on T-5s and other cars exported outside of the US.
I checked the T-5 registry site and from what I could determine the VIN / data plate info for T-5s is the same except for the fact that the DSO is in the 90-99 range. Is there anything else (besides the badges, etc) that can be used to identify these cars? Did they all come equipped with similar options (like the pace cars)?
I've also heard that Canada had unique DSO numbers (as opposed to the generic 90-99 used for exports). Does anyone have them available? Do any other countries have unique DSO values (Mexico maybe?)?
Lastly, a thread recently came up where numbers were used for the engine codes. I was informed that this was done sometimes when the cars were being exported to countries that use lower octane gas. On the T-5 site the engine codes were the letters that we normally see. Does anyone know what countries got the cars with the numbered engine codes and if they have a unique DSO? The reason I'd like to know is because if someone tries to enter a VIN with a number for the engine code then I'd check to verify the DSO, etc. are correct before accepting it.
Thanks.
Oh, If you want to play with the registry go here. It's more of a skeleton with some guts right now but it's starting to look like something. Feel free to put anything in that you want (good or bad data) because everything will be deleted prior to going live.
· Registered
Hi,
as you visited our site, you read most of what we know today about T-5s. In the detailed registry showing all VINs, you can do your own research. As you may have noticed there is a certain sequence in DSOs on an almost quarterly base, although there is another assumption that the 90-99 DSOs refer to sales volumes in that specific year,although both theories have not yet been made waterproof.. There is yet no evidence. I have checked with some Mustang clubs around the world. The DSOs you see on our site are not specific for T-5s nor for Europe. You may find them elsewhere in the world as well, although there is a certain number of 97-99 in the Australian/New Zealand area. Yet no evidence, again or registry of DSOs.
Don't forget the South of the Border Registry of Dave Hammar and the Netherland assembled few early Mustangs.
Regarding the engine codes, there is indeed no different engine for a T-5. I remember only one year, where a lower compression engine was available vor export only, but I would need to check my binders again (memory access fault again), We have also not yet done specific research on smog equipment. One would think that this was mandatory for export cars, however it is not yet researched nor prooven.
Gives us some reason to watch out for this.
Wolfgang Kohrn
Co-registrar T-5 registry (Founder Gary Hanson)
