1 - 9 of 9 Posts
ok ok, I did not follow the advise I read about installing the screws before the headliner. Couldn't find the screws at the time and did not want to wait.
66 Coupe. Would like a pic of the roof area (with headliner removed) for the visor so that I can get a visual idea of where the holes are.
Any help is appreciated
Here's a pic of the area where the support bracket is supposed to go: it was never welded in at the factory for Midlife...can you believe it?
http://midlife66.com/phasei/rvmirror.jpg
And now the bracket welded in...
http://www.midlife66.com/phasei/rvmirrorf.jpg
Discussion Starter · #5 ·
Thanks, I have the rear mirror mounted in that location with the supports
Do you happen to have a pic of the area for the visor pivot point ?
No, I sure don't. When I read your title about visor mounting point, I was thinking of the bracket that holds them up, not the true mounting point.
Do you own a sewing needle? A really thin one?
Need I explain further?
Dave
I agree with Dave. A little sewing needle can search and locate the holes. Don't know if a 68 is different but I could (upon request) take a pic of Shag's visor holes.
1 - 9 of 9 Posts
