Need some 390 performance tips.
576 Views 3 Replies 3 Participants Last post by  RichLong
I am going to assemble my 390 tomarrow and was womdering if anybody has any tips for me. I am running a .030 over block with forged 10.5:1 comp pistons and moly rings, a comp 282 solid lifter cam, heads shaved .015 with a 3 angle grind (thatI did my-self thanx you very much) and an edelbrock 750 carb. So are their any little tips and tricks to really make my 390 run? Thanx
With a solid lifter motor you can restrict the top end oil passage to force more oil to the crank etc,,Also contact your cam grinder and see if they have a recommended setup for the cam (ie:advance degrees etc)
too much carb there amigo (IMO)
http://www.network54.com/Hide/Forum/74182
Take a look around here , too.
