Car STILL won't start, I have 12V at the coil, and the starter is turning the flywheel, but my distributor isn't turning. It's an accel electronic breakerless distributor, I've replaced the circuit board in it already, and the magnetic pickup looks good. What would cause the distributor not to turn?
pull out dist and check cam gear could also seezed oil pump
there are little pins that keep the gear from spinning on its shaft. i believe there are more up the shaft to the bowl of the distributor. pull the dizzy, grab the gear and with the cap off, try to spin the rotor inside. it should not spin if you have a good grip on the gear. if that checks out ok, then i would venture to say that the distributor wasn't seated all the way down to the camshaft gear or you may have a snapped camshaft (rarely happens)
