Hi,
I'm restoring 69 Mach I and I can not get the turn signals to work at all. The hazard lights work fine. I replaced the flashers and the 20A fuse. Other things tied into same fuse work fine. I pulled steering wheel off to look at the switch. All of the wires are still connected to switch and look good. I cleaned up switch with contact cleaner and even pulled apart connection at end of wiring harness and gave it a shot of cleaner. Any ideas? thanks.
Is everything in the car connected? For instance, your brake lights won't work if your headlight switch isn't connected. I'd make sure everything is connected if it already isn't.
