I had my lights all in and working. After a couple of drives I have a problem. The signals don't work. No matter which way you move the lever you get the front two alternating and the two in the dash going together. The back seems fine. I think this started after I tested the 4 ways. I can't be sure. It is a 66 with all new lights. Could it be a bad ground? What else should I check? Should I check in the front or the back? Could it be under the dash? I just don't know, HELP!
On mine the two flashing in the dash means that you have the hazard lights on /forums/images/icons/smile.gif. Dont know what your problem is tho, sorry /forums/images/icons/frown.gif
I'd disconnect the emergency flashers, what you call the 4-way, and see if they work correctly again. If so, then the problem is clearly in the emergency flasher unit.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Vintage Mustang Forums
