I just installed a new 670 Street Avenger. I followed the instructions to the letter, made no other changes to the car, and now it will not run. It turns over just fine, there is fuel coming through the jets, all the linkage is working right, it just won't fire. Any ideas? It has an electic choke and vacuum secondaries. The choke I wired to the the wire that I ran from the "run" position on the ignition to my alternator.
If it's getting gas then you may now have some electrical problem. Easy enough to check.....An engine needs 3 things to run....fuel, air and ignition.
Since you're getting fuel I'd check for no ignition.. ::
Try unhooking the choke. I put the 670 on my Camaro and it fired right up. I didn't have to adjust anything and it runs like a top. The only thing I did different was to hook the choke to the fuse block. It sure sounds electrical to me.
