Had the leafs replaced a month ago (long overdue replacement of originals). The 65 coupe is now sitting nice and level and the handling is MUCH improved.
However, it may be sitting TOO high in the rear. it looks quite level at the rocker panel but did the 65-66 Mustangs sit a bit lower in the rear when new?
Could just be me being used to seeing the thing sag for the last 20 years. ;-)
Any ideas on the correct height of the rear? If I'm a bit high, will it 'settle' since they're new or should I add a 1" lowering kit. I'm after completely stock appearance for a 65 A-code coupe.
