After I my 69 351W pushed a connecting rod through the side of the block, i purchased a rebuilt 351W short block to replace it. I was able to reuse lots of the old parts; heads, intake, carb, etc, but did end up on purchasing lots of new parts... the clutch and flywheel being the most relevant to this discussion. After nearly a year since the original engine failure, I finally put the engine back in my Mustang (along with the rebuilt T5 transmission) and fired it up yesterday. I was able to break in the cam and engine, but had a rough running engine that shook more than normal. The vibrations shake the stick shift and steering wheel when just moving it through the RPM's on the driveway, feels like a buzzing vibration that changes intensity with RPM. I took it for a short test drive around the block and the vibrations are more continuous under load, and the vibration is more noticeable the higher the RPM's go. Just putting around near idle it vibrates more than it should for sure, but it is less intense.
My findings and troubleshooting efforts thus far:
1. Pulled and checked all spark plugs for good color, all plugs are consistent with one another.
2. Plugs, wires, cap, and rotor are all new and there are no obvious defects.
3. Distributor is from the old motor, which was previously tuned (mechanical and vacuum advance curves) and worked fine before hand, and I gave it a once over before installing it on the new engine.
4. I replaced the ignition module, thinking I was chasing a weird ignition issue, but that didn't change anything.
5. I found a vacuum leak under the carb. Replaced the gasket which fixed the vacuum leak but its still shaking.
6. I have a wideband O2 installed, 12-14 is the range I see it flopping around when playing with it on the driveway, so mixture should be close enough and its not leaning way out.
7. Timing is set at 14 initial, timing advances normally.
8. Quadruple checked firing order and its setup for a 351W (1,3,7,2,6,5,4,8).
9. Popped the valve covers off and reset all the lifter preloads (hydraulic lifters). Nothing was found outta whack, so it didn't change after putting it back together.
Now, I have two theories of what could be going on:
First theory... I used the old harmonic balancer from my old engine and purchased a new flywheel and clutch as the old one was toast (CF clutch disk had a cracked hub which twisted some and then hot spotted the flywheel). I purchased a "lightweight" steel flywheel, with the bolt on balance weight. I made sure I installed the smaller of the two weights as my new engine should be setup for 28oz imbalance (as all 351W should be). The flywheel bolted on only one way, like normal, no issues there. My concern now, is the aftermarket flywheel with the bolt on weight somehow not clocked correctly or is the weight not the right amount?
Second theory... My old harmonic balancer that I reused is one of the fancy fluid damper type balancers. It worked great on the last engine, but I remembered that during the rebuild, I dropped it at some point and it may have every so slightly dented the outer casing (can't seem to find the dent now). After reading up on how these dampers work and the internal clearances, I am wondering if the inner ring is now stuck and I am no longer getting any harmonic dampening.
If anybody has any experience with engine vibrations and is willing to share, I am all ears. The last thing I need is to snap the crankshaft!
