In preperation for a new exhaust system on #383 I replaced the transmission x-member today. The car has a T5Z conversion, but the existing conversion X-member was rather bulky and wasn't conducive to big pipes being routed around it. Puchased a new X-member from Moderndriveline. It's a very nice piece, much slimmer. I was able to unbolt the existing member easilly to remove. The transmission didn't move down, but had to jack up the tail of the transmission ~1" to fit the new one. Trans definately is higher in the tunnel. Seems that I now have some vibration where I noticed none before, also get a low howl a one place in first gear where none was present before, and seems like it may be coming from the front U-joint area. My guess is that the existing U-joints develop a wear pattern, and relocating the tail end of the transmission has changed the angle, producing noise. Yes, no?
You may have altered your pinion angle. With some research you can find the correct pinion angle. I would think it to be around 7 degrees. This prevents binding of the ujoints under torque. I also believe your yoke needs a certain amout of free movement. Is this still there? Look at these two items. Good Luck
2Lman
