1 - 20 of 312 Posts
Hey, It's spring cleaning time, so I have locked the old garage sale post and opened a new one. I will leave the old post up for reference for a few months so that the ads that are still valid will have some more exposure time.
Please post your items for sale/trade/wanted as a reply to this post. This is for local sale only, all other ads should go to the appropiate forums. PM me when your item sells and I will remove it.
Thanks,
Charles
Stock C4 and torque converter from my '66 conv., worked great when removed, upgrading to AOD. Make offer.
5.0 crank, turned 10 over, never used. Make offer.
89 5.0 long block, unknown mileage and condition, has bad lifter and wiped cam. Will remove heads and pan for inspection. Make Offer.
PM me.
$700 OBO.
These are the Performer, not Performer RPM.
2.02 Intakes, so you probably will need cut or dished pistons
I am upgrading to AFR 205's, and these are coming off the stroker.
Randy
I want to buy a used auto body Rotisserie.
(Not interested in building one either) :chainsaw:
Would also rent one. What ya got?
I got one, but have a coupe on it. If I can get the suspension under it, you can use it. Need to get the Monarch rear end under it and front suspension on it. Have everything, just need to do the work.
Does any body have a decent 65-66 radiator support assembly from a parts car they can part with. Accident left mine well tweaked. LMK.
Rod.
Pate is right around the corner. Time to start planning.
I go to Pate to buy, so I don't take anything that isn't pre-sold.
Have: a 69 Left drivers side headlight bucket, no broken tabs $125.
Have: A pair of chrome 14x6 Magnum 500 wheels(no caps), fronts look good, I think the backs where surface rusted.
May post other stuff later.
Need: A 65/66 steering column, just the column assembly with the turn signal base/head on it.
Need: A set of buckets for a 65/67. Condition doesn't matter, as long as they are cheap and have good frames to build on. High school kid (low budget self builder)down the street from me needs them for a 67 coupe he is building.
Need: 64/65 Ranchero parts. Hood, Granada spindles/backing plates to build on. May need more I haven't seen my Ranchero yet. From the pics, I think I need a back bumper. May need V-8 springs.
Need: one E-T 14X6.75 slotted wheel in standard offset.
would buy a pair to get one. Also,looking for a pair of 15x5? or 6?, E-T slotted wheels. Haven't been able to find any E-T's less than 7.5" in a 15" wheel, so I don't know what the actual width is. Of course, the wheels would be 5x4.5 bolt pattern or uni-lug.
Need: Dual Point Distributor for small block Ford, Aftermarket is fine as long as I can put a Pertronix in it.
Free Stuff - must be picked up soon, or its is going to the trash
Starter off '69 302, manual - used reman, great condition
Fan Shroud - '69 302, used repro, some nicks, but works fine
Rear Manual Brake drums - perfect condition, and painted, includes all brake parts and backing plates
Slapper traction bars - good shape, no rust
302/351 Dipstick tube and dipstick - chrome
'69 302 Alt - painted black, works great.
Stuff for sale: All prices are OBO
(Engine parts are off my stroker that pulled these dyno numbers http://home.swbell.net/rwking/dyno.jpg)
Hyd. roller cam setup $100
232/240 @.050, .566/.567 lift, 112 LSA. Includes lifters, spider, and dogbones
351w Ebrock Performer Heads $700
2.02 intake valves
Harland-sharp roller rockers $75
351w Headman headers for a '69 stang $75
351w Ebrock Performer RPM intake $110 (spoken for)
Ebrock Perform RPM Carb 750 CFM $100
351w MSD Distributor $125 - steel gear installed for roller cam, but have original cast gear
'69 V8 Front suspension (Will make a deal) - Nearly complete setup. Missing the
steering box, and cross member. This was all restored, before I went to the Rack and Pinion setup.
Near mint '69 heater box $100 - includes motor, defrost plenum, and new cables
Decent '69 passenger fender $50 - needs holes filled where fender flares were attached.
302 Flywheel $60 - will make a deal if you take the pressure plate
302 Pressure Plate $25 - about 5000 miles on it
351w Comp Cam XE274H-10 - $50 - http://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=35-246-3
I pulled 329 rwhp on a 351w with this cam.
351w Oil pan $20 - Chrome, no dents, no leaks. I got it from Dallas Mustang
'69 Battery tray and hold downs $15 - repro, great shape
351w Melling HV oil pump and pickup $20
Send me an email, or give me a call
Randy
972-516-1970
Hi guy's I am looking for a 69 coupe parts car.Needs to have a good roof so i can fix mine.I also have a 351 cleveland and c-6 for sale.E-mail for the specs.I hate to type.lol
Thanks Matt :)
65-68 EFI Gas Tank Sending Unit with return line.
Bought from Mustangs Plus. Excellent Condition - Works perfect
$55 Shipped
PM me
Thanks,
I have two brand new disc brake rotors to fit a 1968-69 Mustang or Cougar. They are still in boxes. They only fit 1968-69. In 1970 the bearings changed so they will not fit that year. They are from different manufacturers so they look slightly different from each other but they should work just fine.
I will sell them for $30 individually or $50 for both. They are heavy so shipping would be expensive. No charge for shipping if you come and get them.
Wanted - Front crossmenber for 66 coupe. The one that goes right behind the oil pan. I'm nearing the end of the resurrection of this coupe which has not been driven since 79. Just fiqured out I am missing the crossmember.
I had a stack of 10 or so, sold them all off for $5 - $10. If you go to ebay, you will find them cheap, but shipping is high. There will be a bunch of them at the Pate Swap meet next month. BTW, there is a "dent" on one side, to clear the Pitman Arm, on the "underside" of the brace.
The 67/68 look similar, but have longer flat ends at either side.
I have a '69 coupe parts car (no title) for sale.
body-wise, it's extremely rough, but it has the 302 engine, c-4 trans, 8" rear end, all glass is in great shape,and it has the power steering setup still in it. There are lots of other good parts still on the car. I've gotten a few brackets from it, that's all I needed. I was going to keep it for the drive-train, but my wife is throwing a fit over it being in the yard (with my 2 other stangs). I NEED to get rid of this one fast. First $250 cash, and pull it outta here. Has tires on it, but 1 of them won't hold air.
Located in the Azle, Tx. area, just north of Fort Worth.
Contact Pat @ 817-800-7512.
Pate Swap meet is April 27-30 @ Texas Motor Speedway. I just received my conformation on my spaces that I have. I will be on the corner of Wallace & Eight st. Stop by & visit. We will have a shady spot to sit & probably some bottled water for ya. It will either be very hot or cold & rainy, but be perpaired for both.
Wayne
i have a few items at mom's house in east tawakoni. engine hoist, one of the break down types, in real nice shape 125.00 or best offer. also a 1972 351w longblock. i think it also has an intake on it. 125.00. also an engine stand make offer. email me at [email protected]
1 - 20 of 312 Posts
