So i got my wife her dream car really nice 66 gt having trouble getting a history on the car but it is a factory GT I have a few minor things I want to fix on the car
1) sounds like the throwout bearing is bad. its rattles and is noisy at idle when not in gear. is there a recommended brand of clutch, its got a top load 4 speed someone told me centerforce makes a pressure plate that is a littler easier to depress has anybody out there tried one
2) the radiator is leaking more like sweating from the bottom and there is no overflow tank (i'm going to add one) and it looks like the seal between the waterpump and the engine block is leaking slightly as well , I think there is a spacer between the water pump and the block it pools above it. ill probably change the water pump since i'm in there anyway are there water pump brands i should stay away from?
3) the windows are about 1/4" from the top i've adjusted all the setting as high as the drives and passenger windows will go but to no avail i removed the regulator and the slides on the drivers side and all the slider are in good shape I was thinking id change the regulator out with a new one to start has anyone else had this problem
4) lastly the trans is very difficult to find the gears especially reverse its got a hurst shifter. is there anyone that has a good step by step to set up the linkage i've read some posts and everyone has a different idea how to do it but mostly they talk about neutral and not the rest of the gears
the car is dead stock 289 with 3.0 gears
I think the car was restored and then hardly every driven so most mechanical thing don't like to sit
